Its the way FCD works that is the problem. Heres a quick explanation. Your MAP sensor is telling your computer how much air is going in your engine, and it reads on a 0-5v scale.
Lets say, on stock boost you hit fuel cut around 4.5v (total guess) and for you thats only 14psi. What the FCD will do is clamp the signal right before you hit that 4.5v. So that means you could boost to 20psi if you wanted. The problem with that is your computer doesn't know that your at 20psi, it thinks your still at 14psi. Now your running lean, because you have no safety net (which is what the fuel cut is for).
It should be noted, that once you slap in bigger injectors and get a good tune, your fuel cut will be raised significantly.
