So i have a 1jz. I had it running since the rebuild over winter, but it only ran for 20 seconds then died, then i fixed the injector o ring leak i found. Now it won't start.
I have spark on all 6 plugs
I have fuel in all 6 cylinders
I have timing correct
I have 160-170 psi compression across the board. same as when i pulled the engine this winter.
All the sensors are reading.
Just changed the water temperature sensor.
Brand new plugs as of yesterday. Gapped to .028
My fuel setup is completely new for this year. New pump, new rail, new injectors, new FPR.
Injectors are 880cc, plug right in to factory harness.
Ecu is new this year. I have a power fc.
Car has yet to run on this setup (except for those 20 sec0nds)
My buddy whom i got the injectors from, also had a power fc. So he sent me his tune and i uploaded it on mine. Injectors are only running at 37 percent if i remember correctly
I tried a stock ecu as well and nothing.
Im really out of ideas at this point. And ive pretty much read every google link there is.
If it matters. this is on my 1991 Toyota Cresta.
