JZA70 1JZ into '87 NA
Looking for experienced feedback on which method is better. The extend or reroute.
Option 1 : Extend main harness 18" and rewire JZ harness plugs to MA 70
Option 2: Drill 2.5 " hole in firewall below speedo cable (flat spot) reroute harness over AC and to reversed ECU. Rewire and extend body connectors (MA70 plugs).
Option 3: ???????
This is where I am in my swap. I swapped the JZ fuse box over and installed the wiring for ALT and Hyd fan sensor. I still have a couple of things to do for the AC compressor wiring.
I'm sure there are some that have done this, and I would like to know the best option
Thanks for any feedback
Cheers
Option 3: ???????
Cheers
