1JZ map sensor questions.
JZA70 QC
JZ Engine are the best!!!
Oct 6, 2005
66
A COLD PLACE
I need to know the pine out of a 1JZ-GTE map sensor as I'm going single this weekend with an AEM EMS V2 and I'll be using an AEM 3.5 bar map. I have the pin out of my AEM map but I can't find my stock 1JZ-GTE map pin outs and your help would be greatly appreciated. I found a picture of a 1JZ map here on a thread but didn't have the answer to my questions in the discussions.
What's the pink, green and orange wires? I know there's a signal (input), a signal ground and a 5 volts power, but I don't know which is which.
Any help will be greatly appreciated.
Thanks in advance.
JZA70 QC
Oct 6, 2005
66
A COLD PLACE
Is anyone absolutely sure of what the wires are as I don't want to wire it the wrong way and have electronic issues.
Again thanks allot for your help everyone.
OneJArpus
2,798
i confirmed it this morning.
If you have any doubt take a multimeter and put it on the blue & red wire, but the car in the ON position engine off and it will read 5v
