Hi guys, just got a bee-r limiter for my 1jz. I have a stock jzz30 ecu. We wired it up today using the wiring guide in this thread: http://www.supramania.com/forums/showthread.php?74363-Bee*R-rev-limiter-Installation-Guide-%28JZA70-specific%29 After doing research there seems to be a lot of confusion on which pins the green and yellow wires should be wired to. We tried wiring it in a couple different ways. At first the limiter would be on all the time and the car would misfire. And now you can rev it freely no matter what you have any of the knobs set to.
Does anyone have a bee-r installed on a 1jz jzz30 ecu and has it working correctly. And if so what pins on the ecu do you wire the green and yellow wires of the limiter to?
Any help would be greatly appreciated.
Thanks, Alex.
Thanks, Alex.
