1JZ JZA70 wiring from a 90 MA70 To an 88 MA70
Jeff_5_7
Texas
Ok i picked up a 1990 MA70 mk3 with a 1jz swapped already im in the process of swapping it all into my 88 mk3? The fuse box in the 90 is the JZa70 box i believe. The cart was running and driving just not quite finished.
The problem.
My 88 wiring harness plugs are all different. The 90 has the newer gray ones so the swap isnt entirely plug and play.
The questions?
What is the easiest way to get the JZA70 fuse box in to my 88 mk3? Pull the fuse box and the whole wiring harness with it ? Or pull just the box and try to wire it ot my 88 harness?
What about the body Harness? Do i try to wire my 88 body harness in to the JZA70 engine harness or just pull the entire body harness from the 90 car?
So essentially i would have an 88 car but alll the wiring harnesses and gauge cluster would be from a 90?
