1jz intall question
white87
i have an 86.5 that is dead right now. i dont know if the head gasket is gone or possibly a cracked head, but i want to replace the motor with a 1jz my question is what motor do i use will the twin turbo 2.5 liter motor work or do i just have to go with the single turbo 3 liter newer motor.
lagged
1991 1JZ
new rochelle
if you want to put a 1jzgte in there, you do that, if you want to put a 7mgte in there, you do that, if you want to put a 2jzgte in there, you do that.......and your question is?
rtboy02
62
highland, utah
The 1JZ is a 2.5 liter bi-turbo 6 cylinder. The other engine you are talking about is the 7MGTE, which is a 3.0 liter single turbo 6 cylinder.
Both would require about the same amount of work. The 1JZ probably offers more potential for power and durability, but less torque and less readily-available parts.
