1jz intake gasket
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
IS the 1jz intake plenum gaskets the same as a 2jz ones?
I opened mine up to get to injectors, and found the lower one foldered and was bolted down.
I don't wanna flaten it out and reuse it, it be leak.
Where can I get them.
Thanks.
Moe
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
Toyota/ champion sells the whole complete kit for 1jz. I haven't had the opportunity to order one for my self to get started with my project. But a friend of mine told me he got his from champion/Toyota.
suprastanger507mgte
Hayward , Ca
Kool thanks man. I will call and find out how much it is.
JZA70 QC
JZ Engine are the best!!!
Oct 6, 2005
66
A COLD PLACE
Do you have a link to there websit or phone number?
Thanx take care and best regards!
-- Jeff
suprastanger507mgte
Hayward , Ca
-- Jeff
His name is Jeff.
Gives discounts to Supra owners, just say you are from Supra Forums. lol
Most 1JZ parts are available special order.
Jeff
1-800-327-2087
1JZ-GTE Engine parts
1JZGTE engine parts
overhaul gasket set $ 138
cam cover gaskets $ 15 each
main bearing set .25mm $ 160
rod bearing set .25mm $ 78
flywheel $ 223
timing belt $ 21
T belt tensioner $ 46
starter $ 179
bellhousing for 7M $ 300
cam seals $ 5
rear main seal $ 25
oil pump seal $ 9
head bolt set $ 145
valve stem seal set $ 75
ignition coil set $ 384
crank position sensor $ 71
cam position sensor $ 71
Jeff
1-800-327-2087
JZA70 QC
Oct 6, 2005
66
A COLD PLACE
suprastanger507mgte said:
His name is Jeff.
Jeff
1-800-327-2087
1JZGTE engine parts
flywheel $ 223
timing belt $ 21
starter $ 179
cam seals $ 5
rear main seal $ 25
oil pump seal $ 9
head bolt set $ 145
Jeff
1-800-327-2087
Thanx alot man :biglaugh:
Take care of you and your babe Supra!
p5150
ASE and FAA A&P Certified
Central Idaho
damn man. I wish I would have seen this thread earlier because I was looking right at one of these gaskets today.
ToyoHabu
261
Huntsville, Alabama, United States
I have used this stuff on many gaskets and seals in my engine and it seems to be holding up. I have used it on my rear differential, intake gaskets, and water pump. If the surface being sealed is of high quality you can use it without the paper or metal gasket. make subsequent disassembly painless wel almost it can be messy but it is easy to take a part. The boffins at Rolls Royce aircraft engines are to thank for this stuff and I highly reccomend it.
suprastanger507mgte
Hayward , Ca
Thats interesting stuff. Difintely would be worthwile to keep one in the Toolbox.
Thanks for the tip man.
suprastanger507mgte
Hayward , Ca
JZA70 QC
Oct 6, 2005
66
A COLD PLACE
Man thats an awesome find....you got everything in one package,,,,pot of gold :)
Yep, I kind of scratched my eyes four or five time to be shour I was realy seeing what I was seeing :biglaugh: and I had to get them.
The main reason was to get the exhaust and valve cover gasketts cause I'm going with a single turbo and HKS 264's in the future and I'll have all I need, plus I allready had a cometic metal head gasket so I'll have too now :naughty:
All the ruber seels and gaskets are all there, I can't wait to get them ,,,,,what a deal :biglaugh: :biglaugh:
JZA70 QC
Oct 6, 2005
66
A COLD PLACE
lenny said:
you got ripped bro..its cheaper from champion.
Not aware of champion but I'm not shour if everysingle seal and gasketts would be in chanmpions kits :icon_ques
The one I got is genuen from Toyota and everything is in the kit, as for the head gaskette, I'll put the one I already got from HKS cause the stock one is probably cheaper even if it's in metal too.
What is the quality of there product, are they made here or Japan?
Did you order one from them?
suprastanger507mgte
Hayward , Ca
Champion Toyota, I guess they would sell Gnuine Toyota parts. I think theior !jz stuff is ordered from Japan..but not sure of prices though.
JZA70 QC
Oct 6, 2005
66
A COLD PLACE
Dose any one have the genuine Toyota part number for the complet head gaskett kit for the 1JZ-GTE?
It woul be very usefull,,Thanx guys!
Jeff
