1jz ignitor wire colors
jizake1jz
FTMFW
Feb 18, 2007
146
Lake Zurich, IL
man i'll go look right now, hold on....
edit:
are you just looking for what color wire goes to each pin or where each color goes?
heres the color to pin ( "@" represents the pin so picture this as the ignigtor being vertical):
yellow w/ red stripe @ @ light green (goes to coil #1)
yellow w/ green stripe @ @ blue w/ yellow stripe
yellow w/ black stripe @ @ yellow
red w/ yellow stripe @ @ red w/ black stripe
red @ @ red with green stripe
yellow w/ red dots @ @ red w/ white stripe
white w/ black stripe @ @ black
red w/ blue stripe @ @ black with red dots
let me know if you need anything else!
935motorsports
San Diego, CA
how hard is it for someone to look at a few wires
Impatient are we. Why don't YOU look it up? This information is available online already.
IGT1 Red w/ white stripe
IGT2 Red w/ green stripe
IGT3 Red w/ black stripe
IGT4 Red w/ yellow stripe
IGT5 Red
IGT6 Yellow
IGF Red w/ blue stripe
EO1 White with black stripe
kikwear002
174
Ft myers florida
IGT5 Red
IGT6 Yellow
kikwear002 said:
Can someone please tell me the correct wires that goto the ignitor.
i have a 2jz diagram but it doesnt seem to match up becuase it says grey wires..
I have the 1jz diagrams from http://www.1jz-gte.us/documents/SubDocs1/WiringEFI.pdf
but it says alot of red wires..
thanks.
this is a supra 1jz too.
apparently you can't read when I said I used the diagram online and not all the wires match up. Thanks for the input. Next time just skip by, I hope you don't treat your customers the same way jackass.
kikwear002
174
Ft myers florida
edit:
thanks!
rakkasan
Currahee!!
Fort Campbell, KY
I think he was refering to your notably impatient comment, I found it rude too. Glad you found your info.
kikwear002
174
Ft myers florida
The main problem I had is that my harness was chopped and i had to use a soarer Ignitor plug so the colors were different so i just followed them to the ecu pinout and everything is good now. So happy its almost ready to run!!!
