1jz hell
5l_eater
I LIVE FOR THIS SHIT !
Jan 17, 2007
258
Maryland
OK so I'm driving my supra to vacation a 3 hr trip and i hit little traffic and it cuts off with out any warning never over heated or anything. So i pop the hood and check around and nothing looks wrong so i pull a hose off to cause a vacuum leak and she starts up fine . I decided to say fuck it and drive it anyways and she then wont hit boost sputter like shit and starts to burn rich as shit i couldn't even drive it so i plug the vacuum back in and the idle drops dramatically and when you give i gas she revs up spools ans when it comes back down cuts off . i yank the map off and nothing happens any ideas ?
GotTurbos?
2J = Here; Swap = Near
Apr 24, 2006
951
Dallas, TX
Unfortunately you always start diagnosing with the ECU on these cars. It tends to be the problem about half the time lol.
staticpage
Banned: Scammer, liar, cheat and thief
Oct 3, 2007
310
Cincinnati
check your IC pipes? mine pooped off once and did the same thing. but i would look in to the ecu if its not been re caped I'd have it done.
5l_eater
Jan 17, 2007
258
Maryland
its not throwing codes .. all of my ic pipes r good my dp is loose and so it my test pipe but i dont think that would b the issue ..i guessim gonna try the ecu and go from there
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Went through 2, and said fuck it. I now have an aristo ecu on the stock 1jz harness.
JonoTurbo
Going for broke
CT
5l_eater;1351148 said:
i can run a aristo ecu ? on 1jz plugs ?
No, but you can buy/build an adapter harness, and you'll have to run 3 additional wires for the sequential injection system of the aristo, and you'll have a reduced rev limit.
I would recommend repairing the ECU first. I fixed mine 2 years ago and it's been fine since then.
