So today my 1jz swapped mk3 starts missing out real bad. I simply think it needs new spark plugs so I went and bought new plugs. Put the plugs in and the car wouldn't start, wouldnt even turn over. Pulled the plugs back out and there was gas sitting in the cylinders. There was even gas pouring out of my wastegate :aigo: ... The car has a Stinger ems stand alone. Would this be a problem with the ecu? or something wrong with the injectors? After we cleaned out the fuel we put the plugs back in and tried to start the car. It cranked for like 2 seconds then stopped turning over. Pulled the plugs again to find the cylinders full of gas. I'm lost on what to do to fix this problem. The ground for the injectors seems fine to me.
