1JZ engine with 6 speed 2JZ transmission?
Bimmota
8
Oshawa
Hey guys i have a 91 1jz engine, is it possible to bolt on a 6 speed getrag tranny from the 2JZ engine. What do i need to bolt up a 6 speed to my 1JZ?
RockPaperSwoRD
I have aCustom User Title
Jul 26, 2008
392
SanAntonio
if you have the transmission, you would know it would bolt straight up with no modification, use 2jz clutch parts. if it is going into a mk3, you will need to open up the tranny tunnel and the rear end ratio is too short for the mkiv trans
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
There are 2 real options for the gearing, swap in a MKIV rear pumpkin, or go with a 9" setup. Last time I talked to jawsgear, they were not producing any more 3.55 rear end gears for the G series dif.
Bimmota
8
Oshawa
Ok thats good the 6 speed bolts right up to the 1jz. so which flywheel do I need to use? and will I be able to the 1jz starter
Bimmota
8
Oshawa
Well to tell you the truth im Putting the 1JZ into my 92 BMW 325.
I found a 6 spd tranny for a deal. I just want to know what parts i need, to make it work.
Witch flywheel?
Use a 2jz Clutch?
Can I use the 1JZ starter?
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
Witch flywheel?
Use a 2jz Clutch?
and 2JZ V160 Flywheel and clutch setup from stock to Tilton triple will work. depends on what you want to spend.
theres pretty much no difference in the 1J and 2J starter
Bimmota
8
Oshawa
Poodles;1427407 said:
Hmmm... the V160 isn't cheap by any standard LOL
What's the rear gear ratio in that car?
I have 3 different diffs 3.91, 3.13, and 3.23
SO the flywheel bolt configuration for the 2JZ is the same as the 1JZ?
They dont have different diameters?
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Use the 2JZ-GTE v160 clutch & flywheel. The carbon tilton one brand new is about 7k+ what do you expect its not carbon material its pressurized true carbon carbon nearly to the point of synthetic diamond. The starter is the same.
Use the 3.23 Diff its nearly identical & ideal for the V160.
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
the flywheel bolt pattern is the same between the flywheels
the flywheels are not the same tho.
Bimmota
8
Oshawa
So Ill have to problem running 2JZ flywheel, 2jz clutch, V160 tranny and my 1jz starter and i should be good to go
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
if you need a V160 flywheel, i have a friend with one that needs to be resurfaced. came off a 1998 Supra with 48K miles
