I was dropping my 1jz today and man, i was having more trouble then ever. I now have one of the 2 bolts in, but the engine is just not dropping well. Do people keep the abs lines with the 1jz install. Any advice is incredibly appreciated.
Thanks.
The rear of the turbo is hitting the abs lines.
We got the one nut on, but the other side is about 1/2 inch away.
I have connected the drive shaft already.
EDIT:
I pulled the engine out again and removed the lines to be safe. Umm, does everyone put the drive shaft in while you drop the engine, or can you do it afterwards? I have always done it while i drop the engine, but i was thinking about doing it afterwards.
Edit:
yeah, i have an engine leveler, but one side is just a tiny bit lower and so the bolt is not lining up. the tranny is just a litle angeled. I am going to try again.
Thanks.
EDIT:
Edit:
