I know this has probably been discussed before but i'm not able to search. I finished my 1jz swap and just recently wore in the clutch so i thought i would get on it a lil and it starts cutting out around 4500 like its hitting fuel cut or something. My setup is a 1jz with a 60 trim ct26 as of now its at stock boost which is 7lbs on the ct 26 waste gate. I have SARD 540cc injectors, walbro pump, aem wideband, 3inch divorced downpipe full 3 inch exhaust, spec stage 3 clutch, ngk iridiums. I can't seem to find out why it is cutting out, it just starts losing power and it runs really rich during boost. I want to get it tuned but i don't know if this cutting out problem will be an issue. Any help is appreciated.
