I am at the final stages of finnishing my M3 BMW project with a 1jzgte engine conversion, the whole car loom has been removed so all I have is the 1jz engine loom and ecu in the car, I need some help from the pin out diagram below to get this engine running, I just need the basics IE what pin out needs to go to a live, ignition ect + any relays needed, as if this engine was being run off a bench as such.
My second problem is installing the emanage blue additional injector harness, I have searched on here but found a couple of different sequences to wire this in I just need it confirmed.
any help will be much appreciated :icon_bigg
