Ready?
The starter. See something missing?
Rod cap and the two mounting flanges for the starter.
and theeeeeeeeeennnn...
Cracked the bellhousing.
Pieces o' the block with a little bit of the oil pan.
And the final result:
From what my buddy told me that I can remember, his A/F was reading all sorts of Lean. Under WOT, his wideband would stop giving a number and would just say LEAN. Cylinder #6 felt the pressure and couldn't handle it. Smashed a hole on each side of the block and finally exiting out of the oil pan taking the starter with it. He's bummed about it, but it gave him a reason to finally go 2JZ. He'll probably chime in more about it when he sees this thread.
So watch those A/F ratios, people! There could be more to it though if someone has an idea of what it could be.
