1jz cams on 2jz head?
donnytran85
5
SoCal
:1zhelp: Does anyone know if this works? 1jz cams on a 2jz head? I just cant find the cams for the 2jz... Help? :1zhelp:
JonoTurbo
Going for broke
CT
Since 2j cams have to be reground to fit the 1j head, I assume that 1j cams don't fit in a 2j head. Plus, you don't want stock 1j cams in your 2j head.
donnytran85
5
SoCal
Well I would think that it wouldn't fit. But still I just cant find 2jz cams for my head due to i'm putting a 2jz head on a 1jz block. Thats what i'm doing.. Sorry help please.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
EvoLuTioN said:
1J cams dont fit on the 2J
Why not?
Last time I tried, they seem to fit fine.
2JZ cams don't fit in the 1JZ head because one of the journals is too narrow on the 1JZ head for the cam. This means a 2JZ head has a journal a little wider than the 1JZ cam, which would work fine.
tissimo
Stock is boring :(
Melbourne, FL
annoyingrob said:
Why not?
they will fit, but isn't correct. Its like putting a STD size piston in a bored block, itll fit, but isn't right.
the first journal is what keeps the cam from walking forward and backward
