So I picked up this 88 Light Blue Front Clip Swapped 1JZ With A Set Of Volks, 89 conversion except the front bumper and cluster with and the cleanest stock interior I have seen. Interior is blue as well. The car also had a 3in exhaust with a flowmaster muffler.
I drove down to Fairfax, Virgina about weekends ago and pick up the car. Bought it from a guy who didn't want to fix the car. It was well kept interior wise and the body was spotless. We agreed on a good price an I took the car and brought it back with a U-Haul. My fifth Supra....
We pulled out the engine yesterday and stripped it down. It got late and we left the head on, but the car did have ARP flywheel bolts. . Maybe some ARP on the inside too? Hope so, will know this afternoon!
I cannot help but say, and said it many times getting the engine out, it was a great swap. The person bought a front clip and sued everything to make this swap perfect and clean. Even the EVAP sensor under the intake was hooked up. Car has A/C and power steering which works.
Mod List
1JZ ARP Head Studs
1JZ ARP Main Stud
1JZ Rings/Bearings
1JZ Gasket Set
1JZ Thermostat
1JZ Toyota Radiator Hose Set
Koyo Radaitor
1JZ Fan Clutch
1JZ Fan Blade
1JZ AFPR
1JZ 60-1 Turbo Kit
ACT HD Clutch Six Puck
Headwork
Plain Head
HKS 264
HKS Cam Gears
Springs And Retainers (Suggestions?)
Valve Seal/Valve Grind
Port And Polish
HKS Timing Belt
I plan on breaking in the engine using the stock fuel system, the 370CC, then upgrading the rail, -8 fuel feed and -6 return along with a walbro intank and walbro inline pump. Should be enough for my power goals. Maybe dual intank instead.
Tuning will happen after my engine is broken in. I will drive the car even after the engine is broken in with the stock fuel system. Spring is when I will do the fuel upgrade. I will be getting a Stinger and plug and play harness from Driftmotion.
Pictures
Mod List
1JZ ARP Head Studs
1JZ ARP Main Stud
1JZ Rings/Bearings
1JZ Gasket Set
1JZ Thermostat
Koyo Radaitor
1JZ Fan Clutch
1JZ Fan Blade
1JZ AFPR
1JZ 60-1 Turbo Kit
Headwork
Plain Head
HKS 264
HKS Cam Gears
Port And Polish
HKS Timing Belt
Pictures
