1jz automatic tranny sway ?
ronnie4
136
Huntsville
If I swap a 1j with automatic tranny into my '88 with auto tranny, will the factory driveshaft work? This would be using the BIC motor mounts.
Thanks
ronnie4
136
Huntsville
Alright, a few more questions?
Will the stock 7m shifter linkage work?
Are the 1J and 2J auto trannies the same?
Thanks
ronnie4
136
Huntsville
supr88;886038 said:
my 7m linkage worked just right.
Thanks a bunch man
So I am still debating between the 1J and 2J. From what I can tell, the automatic tranny on the 1J bolts right in (driveshaft, shifter linkage). Does the 2J bolt in? Any other differences I should take into consideration before making my ultimate decision.
bluemkiii
redmkiii's little brother
Jul 25, 2007
729
phoenix, AZ
ronnie4;886203 said:
Thanks a bunch man
I believe the 2jz auto uses a different driveshaft, but don't quote me on that.
