1JZ and 2JZ fuel rails interchangeable?
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
negatory.
I believe the spacing of the injectors is different. The fittings are DEFINITELY different. The 2JZ has a FPR that bolts to the top of the manifold, as opposed to the end.
Sep 10, 2007
482
Virginia
annoyingrob said:
negatory.
ahh i see, thanks for the info. so if the 2j injectors can drop into a 1j rail, are the harness clips the same?? i know i've seen a thread about the differences, is there a certain year range 2j injector that you need to drop into a 1j, or will any do?
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
1j = sidefeed
2j = topfeed
no match
annoyingrob
Boosted member
Jul 5, 2006
2,304
2JZ-GTE injectors will drop into the 1JZ rail (2JZ-GTE = 550cc), the injector clips are different, but you can make them fit with slight modifications. You need to wire in some resistors to the injectors as 2JZ are low impedance where the 1JZ expects high impedance.
Sep 10, 2007
482
Virginia
thanks, i thought that was the case...do you have any more info on wiring in the resistors, i.e. what type and where?
thanks for the help
annoyingrob
Boosted member
Jul 5, 2006
2,304
thanks for the help
Any high wattage ~10ohm resistors work. The best place to get them would be a 7M resistor pack. You wire them in series with the black wires on the injectors. The black wires are 12V from the battery.
Sep 10, 2007
482
Virginia
awesome, thanks man!
