Looking at options with my next swap. If I have a JDM 2JZ, Auto ECU, auto flywheel, MKIII auto-driveshaft and shifter, would I be able to bolt up a 1JZ tranny from a Supra or Soarer (the target car is originally an auto).
I can pick up a 1JZ auto tranny for next to nuthin' (~$100) and not have to swap in the 5-speed (pedal assembly, clutch master cylinder, bellhousing, clutch, PP, flywheel...near $950 and alot of work).
So, can I just bolt up the 1JZ auto tranny and use the standard MKIII auto driveshaft? Any additional electronics, or with the JDM aristo ECU do the same as the JZA70 auto ECU?
If soomeone's got a JZA70 auto clip, it would really be helpful to know more about this option. Email me!
Thanx,
E
g099521@yahoo.com
Thanx,
E
g099521@yahoo.com
