I have seen that the stock twins on the 1st gen 1JZ's seem to go bad. I guess the PCV sucks in a lot of oil and then destroys the stockers on the car. If I did cap off the stock hole it comes through and relocate it down the tube farther, basically what the 2nd gen has or further would this be worth doing?
What turbo generally goes out 1st. My front one does not spins * as well as the rear, I think it's that or the other way around I will check though.
To get the car running I want to use stock twins- after a while I will go to a single, and then a tuning device, but I want to see this motor start and run first.
