1j swap
Feb 28, 2008
192
North Babylon, New York
ok i'm currently in the middle of a 1j swap and was reading about only being to get up to 120mph like a top speed cut or governor how do i get around that and what psi will you hit fuel cut on a stock 1j i have a hks fcd k3 from my 7m will i be able to use that??
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
to get around the speed govenor you can get a speed cut defender or cut the pink wire to the ecu or something, i'm not really sure haven't done it myself if you do a search on speed cut it should tell you what to do with the pink wire. i've heard if you cut that pink wire it will make the car idel rough
