On my first start it started up and idled ok, but now when i try to start it it will die unless i hold the throttle open.. otherwise it revs fine.. I currently have direct 12v from the battery to the ecu, injectors and fuel pump. But my alternator is not hooked up. The engine still makes a bit of a weird sound ( in my other post http://www.youtube.com/watch?v=SepbTAWKDXQ ) After re-putting on the timing belt the sound is not as bad as it was in the video, but i still have the problem of the engine dying without throttle. ( there currently is no throttle cable hooked to it if that makes a difference.. :nono: )
