1j or 2J manifold
mk3supreme
Hoes Anyone?
Jun 27, 2005
69
Los Angeles
will a 1j or 2j intake manifold fit on a 7m i just wanna know because i want to change my intercooler setup so it has less bends, and more of a straight shot for boost to flow in
Idealsupra
Orlando
www.tampabaysupras.com
rakkasan said:
Does someone make an adapter? If not, why not?
no one makes a mass produced adaptor that i know of... you have a few options when adapting it... you could weld the lower runners of the 7m to the high runners of the 2jz... or you could weld the lower runners of the 2jz to the low flange of the 7m etc....
its not THAT hard to adapt...its just more work then necessary when for ALMOST the same price you can get a complete NICER one off ala rons style...
MK3less
Money eating monster
Jun 3, 2005
68
Mass
by doing this is their any hp gain or is it done only to clean up the bay?
drunk_medic
7Ms are for Cressidas
Woodstock, GA
Well now.. if you do it RIGHT, you are going to use larger diameter tubing, which will flow more air, and you will be getting mandrel bends which are constant diameter [you would shit if you pulled out all of your intake piping and looked at all of the bends put in there], and there are going to be LESS bends for the air to go through. You will also be using an aftermarket intercooler, which will be more efficient than the stock unit. It is in my opinion that there will be a horsepower gain. It might not be a ton, BUT it will ready and benefit you for upgrades further down the line.
