1j in 88 ma70
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
im just wondering what it is going to take to put a 1j in my 88 supra, and is there a place that make a harness extension or do i have to just cut mine and make it longer, also i have an 88 as you guys know the 1j mounts wont work in the pre 89's right so in order to get everything to work i have to get the BIC adapter kit for the mounts or get the newer crossmember ?
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
BIC mounts
BICperformance.com
yea just cut the harness in half and solder a way!!!!
and have fun
Seriously tho......theres a shit load of threads and stickies about this.....please read and search my friend
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
i know how to solder just wondering if there is an easier way then cutting and soldering,also are those mounts nice, if i understand right you can use the square mounts with those correct.
The Reaper
Jan 10, 2006
1,909
Florida
yes i have an 88 and i have the BIC mounts and square mounts on my 1JZ right now worked beautifully.....
you can run the Wiring harness through speedo cable whole supposedly and all you have to do is wire up the body connectors.
88supraFAST1
7M WHAT
Feb 8, 2006
421
Battle Ground, Wa
thats what i was thinking of running it some where else and just mounting the ecu and running wires to the under dash harness, does anyone make a plug and play harness.
The Reaper
Jan 10, 2006
1,909
Florida
no one REALLY makes a plug n play harness
its not hard its only like 4 clips you'll have to extend
OneJArpus
2,798
its not a little wiring, its actually alot but depending on your experience with wiring harnesses it maybe easy or it maybe a nightmare. i got a jumper harness made from DM (Aaron & Jose) When it came in it looks great.
tturnpaw
Supra Enthusiast
Feb 10, 2007
412
Everett, WA
if youre like me, just get it done. I spent 6 hours one day soldering a good 80-100 wires in a main wiring harness for my escort...of course i had to diagnose which ones i wanted to solder, not just lengthening. I can tell you now, i never want to solder that much EVER again. If youre lazy (like someone on the forum here i know) cut a new hole in the firewall and route it though there.
88supraFAST1 said:
im thinking about doing it my self i have made the harness long on a few sr20's before i just dont know about the wire on the 1j and how many wires need to be longer. and that fun jazz.
