supradaddy0803 said:
It is like your head bolts you are really supposed to replace them every time you remove them. They are made to take a certain amount of tensile strength put against them but once they are stetched and heated up as much as the studs there get I would just order some replacements and replace them that way you know they are good.
I'm sorry, but that's just plain BS, they're nothing like head bolts.
Headbolts can be re-used about three to four times, no problem. However it does depend on why you removed the head though, if you suffered pre-ignition damage I would replace them; they did take quite some beating then. If you took your head off just to do a head job you can re-use them no problem.
Manifold studs, come on man, off course you can use them over and over again. It doesn't just break because it has been doing it's job and you gave it a bit of relaxing and then put it back to work again. It's just a stud made of steel which holds up it's strenght and shape better during heating than ordinairy steel, it's not a stretch-bolt or something.
Studs only need to keep the manifold in place. If you have some leakage after re-installing a mani just yank the nuts tighter.
The only reason I would replace a mani stud is if the thread was worn or damaged.
