1ggte style intake and intercooler pipes on 7mgte
Iirc they will fit, but its not worth it as the inside diameter of the pipes is super small. Would be a major bottle neck.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
I can't see any advantage to this whatsoever. The pipes look tiny. Hommersimpson did something similar on his 7M a few years ago, look into that.
Wrong section, too.
red90turbo
27
Vancouver,Wa
Just wondering they looked cool, but not good enough to put a 1ggte in, sorry for the post in this section, i think i might make my own custom pipes that look like the 1ggte
mk3_7m
536
melbourne
Something like this ???? ^_^
The only issue for mine is being moving the radiator fan on the other side as there was a clearance issue since I was using electric fans. Other than that it's all good although if you're using the stock clutch fan i think they'd be some fitment issues too. Though one guy shared this design on my build thread which I think you'd be better off with as it leaves more room.
Canuckrz
852
Calgary, Alberta
Only one small section of the pipe runs across the top of the engine bay VS a large section both comming off the turbo and going into the intake.
