1G-GTE
Schiffer
I've been trying to gather some info on the 1g-gte. I was wondering, how much does it weigh compared to the 7m? It sounds like a reliable engine, and could get as much power as a decently modded 7m, so if it weighed significantly less, it might be a good way to cut down on some weight on a MKIII Supra. But it also seems like there is hardly any aftermarket support for it. Another idea came into my head as well. Instead of using it in a Supra, could it be possible to swap it into a MKII MR2? Since it is a 2.0, the size shouldnt be an issue, and you would have two more cylinders than with the 3S-GTE. But is there a transmission that would bolt up to it transversely? Just some thoughts if anyone has some input.
Dylan JZ
一番 King
Oct 18, 2007
2,220
湾岸せん
annoyingrob said:
The motor won't fit in a MR2. It's a LONG motor. It would stick out the side :) Why not stick a camry V6 in the MR2?
FTW.. some guy around here is doing that, plus boost apparently.
us
BlackMKIII said:
Dude, since when does displacement have anything to do with the physical size of the engine? there is no way it would fit in an SW20!
OMG, sorry I just suffered a brain aneurysm. I am dead.
thank you. me too! the 1ggte isn't any lighter than a 7m, they are pretty close to the same. and just to put in perspective, an ls7 7 liter v8 weighs less than a 2.0 liter 1ggte. and mr2's are mid engine, so no, an inline 6 wont fit. does that answer your questions?
Schiffer
hahaha dont worry, I'm used to getting kinda chewed out like that, I have been known to think some retarded thoughts...no hard feelings
