1g don't go part 3
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
alright guys... watch this vid and tell me what you guys think
the bright yellow things you see are flames
car can rev 3000+ and is clean and on all 6
down low it idles like crap and generally stalls unless you keep on it
timing is perfect on dizzy, crank - cam timing is also tdc
have tried 3 afms
last part of the vid is when cranking via the key... vroooom stall vrooom stall
first part of the vid is revving via the flapper door
i'm stumped!
www.supra.co.nz/lisasflames.wmv
suprra_girl
7M POWAH! ;)
www.supra.co.nz
well that's the thing... if it idles low it pops n stuff
really sounds like popcorn LOL
but when you rev it, it revs perfectly fine... just 3k sorta down it starts idling like a bag and at really low revs it starts popping n flaming
dizzy & cam/crank timing has been checked multiple times today
the only other thing i did think was awfully odd today was the dizzy was out one tooth (again???) reset it to fire on 1
but changing it one tooth didn't make a difference to the running of the car :s
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
my 1g was running like crap cuz of the timing being off. i reset it finally and it runs good except. when i run it hard and its kinda hot outside the car will shut off and the only way to get it to go is manually restart it with the key. but it sounds like a valve problem to me!. any ideas why mine shuts off?
