I've been ready for a wheel change for awhile now, and have found a set I like.
The front size/offset will fit fine (18x8 +37), but I'm not too sure about the rears.
They only offer a 18x10 in a +40mm offset.
By referencing the oem sawblades (+37mm) and using a wheel fitment calculator, this offset will reduce the inner clearance by 41mm (1.614") and will extend the outer edge of the wheel by 35mm (1.377").
Has anyone used this wheel size and offset on a MK3 without rubbing?
(fyi - My suspension includes Tokico lowering springs and stuts)
Thanks!
Thanks!
