so i have a 57trim ct-26 ,rc550,walbro 255, lexas v8 afm, perrin boost controller, turbo back titan down pipe, blitz nur spec exaust, titan meat hg, arp studs, all mandrell bent hard pipes, xs blow off vavle.boost was set at 12 and ran strong with no issues. i want to set boost at 15 psi, so i did the 12v mod with new relay and all new grounds 10g wires. go for a test drive and as soon as i come to a stop the engine dies. and when i go to wot it hits fuel cut. So my only gues is I'm running realy rich. is there anything i can do to lean it out, or do i go back to 6 volt to power the walbro fuel pump?
