12.2 at the track
Is that a projected time that it shows? It looks like the light lights up like seven seconds after you take off............maybe I'm just seeing things.
Your car does take off good though. How much boost are you running?
suprakid24
Turbo'd
Jan 6, 2007
521
Texas
are asking if the 12.2 is a projected time? thats the actual time that I got on my time slip... maybe i don't get what your saying. im runnin 21lbs. whenever im going fast lol and 18 most of the time. it was 21 at the track, and i have the 2 step setup on my aem and some m/t street tires. i was surprised that it hooked up that good, because the last time i was down there, it kept spinning even with the m/t. maybe the track was prepped better or something, because that was the first run that i made that night and it felt really good. the only problem is that 2nd gear is a turd and doesnt like power shifting, it seems like i pull back, it stops, then i keep pulling, then goes into gear. but ive been reading and im guessing that its normal for some of the gears to be stiff on the R154.
I seen the lights flash up and that must be your 1/8 mile or something and then it flashes up again. The first time it flashes, it is only about seven seconds into the run, so I'm guessing it is your 1/8 mile time.
What suspension mods have you made? Do you have upgraded traction arms and sway bars? Are you running MT slicks or drag radials? I'm guessing slicks since you're hooking up really good. Great time. I'm probably making as much power as you and you're a second faster than me. I'm having problems with the guy that machines my flywheel. I gave him a second try and I think this one is screwed up again causing my clutch to slip. I'm through racing until I can get my clutch and flywheel to like each other. Great run again.
suprakid24
Turbo'd
Jan 6, 2007
521
Texas
yea the first time the lights go on is the 1/8, but at the end someones head got in the way so you cant really see the time at the 1/4. i have a tein suspension, and the camber and traction rods in the back from A-1, i dont have upgraded sway bars. i use the m/t street slicks, so they have just a little tread in them.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
That thing screaaamed off the line!!! Nice run hey was this the Edinburg International Track by any chance it looks familiar.:evil2:
suprakid24
Turbo'd
Jan 6, 2007
521
Texas
s turbo 87 said:
nice run, what mph was that? 113?
gt4088r? turn the boost up and run 10s
yes it was 113, and yea its a gt4088R, the boost is at 21lbs, if I push it anymore it will break the 500hp mark at the motor (even though 21lbs already does a little :evil2:), the motor is stock. i dont want it to go out on me.
logan said:
How much boost are building at the line ?
around 10lbs
yes it was... how do you know :biggrinbo
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
30 psi on a gt4088 is way out it's range, i've very doubtful he'll drop to a 10 even if he ran 30psi on that turbo he'd need a 40R and he'd be LUCKY to hit a 10 even then. An auto may do the trick.. Nice car man, not many 7m's doing more then a mid 13.
There are some fast one's but the majority are stuck in the 13 second range.
