1 jz tranny help
AZN MK3
341
Now in the U.S.
Brewster said:
if you're talking about using a r154 you'll need a 1jz bellhousing and flywheel.
do i have to get the 1jz bell housing???? well wats the difference anyway.. wat if i use the w58 tranny??? well i knw i have a r154 tranny.. also u talkin bout the flywheel im was lookin at an aluminum flywheel for a 7m gte and i was wondering will that fit too???
Trust_GTE
BOOST NOW...CRY LATER...
Apr 4, 2005
120
FL
Yes, but the 7m flywheel will not work. Either get one for the 1J or have 2JZ bolt pattern drilled in if your looking to use one for the 7m. IMO just get one for the 1J.
