1 jz part list...
AZN MK3
341
Now in the U.S.
well i bought the 1jz engine and tranny package which i got the engine, tranny, ecu, harness etc... and well i was wondering what other parts will i be missing if someone could please give me a part list on doing the swap....and if anyone has any of those parts for sale... thanks
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
look in this http://1jz-gte.us/92Supra8.html
AZN MK3
341
Now in the U.S.
what about the drive shaft do i use the 7m 5spd driveshaft... and what clutch kit is good to use with the 1jz??? also do you guys know if there is a non-stiffening clutch kit out there??
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
The Drive Shafts are the Same R154 they both use the same Manual Tranny
I dont know if you can use the DS from a Supra with a W58 with the R154 that is on the GTE Cars
The Clutch is the Same as the 7M Clutch actually it is exactly the same any 7M Clutch kit you can fit, It's The Fly Wheel that is different.
AZN MK3
341
Now in the U.S.
so what flywheel am i suppose to use... will the one that came with the engine work??? again i bought a engine and tranny package so i dont have to change the bellhousing...
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
Yes you can use the flywheel that comes with the 1jz and if you get a new one it is the same as the 7M but it needs to have a 2jz bolt pattern drilled into it.
AZN MK3
341
Now in the U.S.
well in that case can't i use a flywheel from the 2jz????
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
NO it doesn't fit!!!
just get a 1JZ flywheel or a lightened 1JZ flywheel from 935 and end this thread
re-read the thread.....if you already HAVE a 1JZ flywheel with yur engine set why would you want to get a 2JZ flywheel??? this makes no sense
