1.5j question *PICS*
Boostage
323
Florida
there is a Slight difference between the 1j and 2z oil feed in the heads..
Oil feed area of headgaskets. 1J on top, 2J on bottom
1J head, oil feed area
2J head, oil feed area
2J block, oil feed area
1J block, oil feed area
NokaoiMK3
Drifter..
Jul 27, 2008
275
Gilbert Arizona
Wouldn't it still work with the 2j block an a 2j headgasket with a 1j head.. Im pretty sure it will be fine like that... but if you have the 1j head and a 1j headgasket on the 2j block it doesn't look like it would work.. Atleast thats how it looks from the pics..
RacerXJ220
Interdimensional
Abalama
put the gaskets on top of each other, the holes should line up. I just installed my 1J headgasket 1J head on a 2J block, I haven't had any oil starvation issues.
Also means I can't check the gaskets because I already put it into the car :)
