7MGE Intake tubes degree angle and diameter size?
toyota.s
8
Does anyone know the degree angle and diameter of the 2 rubber intake tubes? They are discontinued from Toyota for the 7MGE. I found a website that sell silicone tubes, but to many to choose.
Find your 60 silicone bend here.
www.siliconeintakes.com
Also, I was looking at pictures, and it there is a vacuum hose that is attached to the first intake tube. Does anybody know where that leads to?
I have a 1987 Supra 7M-GE Auto.
  • Like
Reactions: Nick M
Oct 11, 2005
3,819
20
Thousand Oaks, CA
If the vac line is attached to the first intake tube after the air flow meter then it is the power steering idle up circuit. That line goes to a valve on the PS pump. (17630 in the drawing above)
  • Like
Reactions: toyota.s
