Just installed the 264 HKS cams. With BC springs and retainers. Also some
Greddy cam gears with Greddy pulleys. I had the car in the shop for 14
days and the battery died...
I first started the car some hours ago and I had high idling 1.400 rpm
for 3 minutes and after it's warm up session it came down to 650-700 rpm.
Low idling...? Why ? And some times it makes a loop down to 500 and occasionaly dies.
Usually they say that you gain some rpms and not losing from installing 264 cams
with a stock oem ecu.
The only thing I can think about is that the ecu was reseted after
the addition of the cams,and it may take some time to make the
correct adjustments.
And my A/F is 13.0 / 1 during idling...... Maybe I am so sich in fuel that
I f''''''ed up my idle
Bookmarks
